washer fluid reservior
TwistedCU
Is there only one fluid reservoir for both the front and rear wndow washers? My rear washers won't wash anymore but for the life of me I can't find another fill for it.
I'm assuming they both work with the tank that is filled under the hood (DS) and that my pump is shot but I figured I'd ask.
There's two pumps under the 1 tank under the hood, pumps for both front and back.
RE: pleaseeeeee help
Looks like my pump for the rear may be bad then :(
Oh well not like I really need it anyway.
RE: Re: Where is the reverse light switch located?
Check for a pinched fluid line or a busted nozzle, especially on the rear liftgate.
Hi,
My Cherokee rear washer doesn't work because the small water hose which runs up the rear wiper arm broke right where it passes through the trunk door to the outside. Perhaps this is your problem as well...
-Nick :!:
