If I may , would like to say that if the motorcraft carb , 2100 or 2150 ? can be gotten to run work well , a Holley two barrel will not be necessary for your 304. I don't remember the exact measurement that the throttle blades should be open from dead stop , fully closed that is , but the blades ( valves ) should be set so that when looking up from the bottom of the carb ( off the engine ) ,
you should see the idle transfer slots , long vertical slots that the vacuum will pull fuel / air mixture directly from float bowl above idle as you accelerate. I think the best curb idle setting was with the blades just above the bottom of slot ( two , one for each Venturi ) to appear like a square so as much exposed will be as long ( vertically ) as the slots are wide .The idle mixture screws will take care of the actual idle speed when rpm and vacuum is set . The electric solenoid does the rest. It is important to note that the two idle mixture screws be even as possible in turns out from fully closed position to avoid uneven feed to right and left cylinder banks and clean idle and clean acceleration to . When turning screws to full close position to count turns out , be careful not to seat screws tight so as not to deform screw tips and seat. A carb rebuild sheet or manual with rebuild specs should have info on turns out from closed seated position as well as choke adjustment . I'm certain the motorcraft carb will be fine for the 304 in good working order. Once again , best of luck . Greg
