The 4 wheel drive light is a vacuum switch, so if you left the vacuum lines at the T-case alone, it should still function
Another idea would be to mount a Normally Closed push button switch by the shift linkage to turn on the light when the lever isn't in 2HI.
Just a thought :idea:
-Nick :!:
