So I bought a used lift kit, but it turns out all I got was springs and shocks...(I got a bunch of stuff at the same time, and I didn't know what I should be getting). It is a 4 inch lift, but now I need a shopping list for all the other parts I need to pick up. So far all I know is I need a drop pitman arm. From there I am not sure. Do I get different sway bar links or just brackets? What about a steering stabilizer? Can I get away with dropping the T-case a bit (how much?) or should I be investing in a SYE? What else am I missing? This is a weekend warrior YJ that doesn't get extreme, just fun amounts of off-roading.
I want to get this lift on, as my stock springs are so whipped they flat or worse and causing me enough axle wrap to be concerned! Will the lift make this inherently worse, or will the new springs make it better? If not, I will install an anti-wrap setup I guess.
Thanks in advance.
Thanks in advance.
