Turn signal problem
Garef
My turn signals have decided to act up. They work, but they either work normal, or they don't flash, but stay on, just producing a solid orange light, which doesn't really help. Any ideas, I thought it might be the relay.
Cheers.
The problem is most likely with the flasher module. I had the same problem in my 05 TJ. My module was on the top of the steering column to the right of the hazard switch. I fixed mine by removing the module, opening it up and lubricating the toggle door joints with a little WD40 and haven't had a problem since. Of course if you aren't as cheap as I am, you can also just buy a replacement at Autozone for under $15.00.
