jackflack44
Has anyone done it? Is it not cost effective? I was thinking possibly I could make my own and then rhinoline them or something along those lines.
I'll try to do that this weekend. It's beginning to warm up a little bit here.Pictures of your setup and your doors would be nice if you had the time?
Thanks. I'll most likely make a cross support bar on the center and plasma cut a skull in the middle with a steel plate that will also be part of the gusset.Looks pretty good, are you only adding one support bar?
Thanks Bud, whenever your ready, i'll build you a set.Very nice Mikey...when are you going to finish mine?
