trasnfer case shifter not moving
BrianPD
2003 liberty... disconnected cable from the transfer case. case moves. shifter and cable does not. Need new shifter? or is it rebuild able? Its locked up tight, at least my friend does'nt have to buy a transfer case:)
try greasing the fittings on the linkage if its not already too late
if you pull the shifter take it apart clean it up and grease the hell out of it
I found the fittings by accident when greasing the U joints after greasing it moves better than it did when I bought it new
Disconnect the cable from the lever and see which one it is causing the issue.
