transmission
dbr5010
RE: drive shaft length
my transmission is got some water in it i changed the fillter and the fluid and it still looks pink is it water comming out of the transmission cooler.
old jeep
cooler, torque converter, and the 14 million other little places in that transmission that fluid travels......
RE: Hardtop weight?
buy a case or two of atf and disconect the line going into the transmission(not the one that pumps it out-the return line)and start flushing it out. Have one guy fill the transmission and the other watch the output of fluid. Or just pump out about 3-4 qts and fill it up and do it again.......next time stay out of the water w/ an auto :lol:
A cheap brake line air flusher pump works good for voiding all moisture from the dark hidden confines of the slush box. Since, the water is thinner in viscosity than the oil, oil will remain, water evaccs.
Robert
