Transmission Cooler Line Leak 4.7 2006 jeep gc wk
laredo2006
Hello,
My Jeep passed a whole inspection with no problems except for a transmission cooler line leak which I've been told about by other mechanics who have checked under the Jeep for a while now... But have said it's nothing serious but should be fixed at some point...
I'm going on a long road trip in July-August...Dealer wants 700$ (About 100$ parts, the rest in labor to fix it)...
What would you do?
Someone said:
"the cheaper way to go is cut the line up by the radiator with a tubing cutter and on the transmission. leave about a inch of line left by the radiator and the transmission. get some 3/8 gas hose and 2 small screw clamps. rubber will be cheaper then metal. if you use metal you will have to use your fittings and flare both ends on the line."
and another said:
Someone said "you can get complete lines from the dealer these lines really can't be mickey moused and are relatively cheap from the dealer"
These are the 2 parts needed according to the estimate:
http://www.factorychryslerparts.com/...5038175AA.html
http://www.factorychryslerparts.com/...8034089AA.html
as well as some of this, not sure why? http://www.factorymoparparts.com/0vu01497ab.html
