trailer hitch..
deke rivers
I have a 04 wrangler unlimited with. a stock trailer hitch..im guessing class a...will be pulling a 17ft fiberglass boat and trailer.is that hitch enough for the boat and also I pull a aluminum trailer with a atv..thanks
The max towing capacity for a TJ I believe is 2000 lbs. I think it will be on the sticker in your door jam. I don't know what size boat or ATV trailer your planning on pulling,but it's best to know the weight of whatever your pulling & make sure it's less than your capacity.
Lj's have a 3500 lb towing capacity...
If it's a factory hitch I'm sure it's capable of towing 3500lbs
Sent from my SCH-I605 using Jeepz
