Alright, almost ready to start fitting them. A note though, on the rear flare if I run the flare the same way as the TJ(rounded arch in back). It makes the part of the flare at the back of my tub sit way to high off the tub line. So I turned it around and sits almost perfect if I turn it backwards with the tab in front. Should I run them this way? I know some of you guys have to be running TJ flares on your YJ's or CJ's. So get in here, help me out.
