Tires
Bonkers
I am looking for help. I have a 95 jeep cheroke and would like to raise it with tires alone. What are the biggest tires i can put on my jeep without having to raise it or cut the wheel wells. Your replys are much appreciated, Thank you.[addsig]
1052109
I've heard that you can't go any bigger then 30's without a lift...but i'm not positive on that.[addsig]
1052135
30's are as big as you can go. with 30's, you may experience some rubbing when the suspension is flexed... and you may have to adjust the bumpstops in the steering.[addsig]
1052203
Had 235X75R15, about 29.5"-30",rubbed turning one way (just a little) on the inside, but not the other direction. I don´t believe I ever touched the flares or the wheel well any.
The 225X70R16´s, about 29", I have on there now (heck they where free) work better on the highway. And I only loose about 1/2" clearance at the differential.[addsig]
1056972
30's are the max & u might get some rubbing as mentioned above. 31's will fit but will definitely rub! Mine 88 XJ has a 2" lift w/ 31 A/T's & they still rub some....[addsig]
