Any box off of another jeep, be it a cj, truck, cherekee from the 70, early 80,s should fit. The 80,s had dif hose fittings though. You can get a siginaw box from a fbody 70,s car (camaro, firebird, mustang) at about any junk yard that will give you tighter turning, it is a popular swap. The box from the fbody cars have 4 mounting bolts and is stamped by the sector shaft with a 76, I have one of these on my jeep. Your frame should have 4 holes for mounting a box but your current box probably only uses three, so the holes should already be there.
