Nhguy
whenever i drive around a corner at slow speeds(5-10mph) the steering wheel wiggles back an forth.not much but noticable.
could this be sign of bad U-Joint at front axle(solid axles).
that's the only thing i could think of that would be the cause..
other weird thing is if i'm stopped and move the wheel back an forth..you can see the whole front end of my XJ go up and down :-|
what are signs of the steering stabilizer needing replacement ?
in a few weeks,i should be able to replace the U-Joints and maybe the stabilizer if needed..
gonna need to buy some things(jack stands,jack and more tools) in order to do the work..(or pay local jeep specialist to do it)
Thanks in advance..
oh..other thing.just one front tire is wearing on the outter edge..alignment due maybe? other tire is fine..
Thanks in advance..
