Cabin_Guy
I'm having no luck trying to locate a noise.
Every time I turn left or right I get this high pitched ( almost like a bird chirpping) squeek squeek squeek coming from my front left wheel. The wheel is on tight and the only things i can think it might be are the u-joint or the wheel bearing. Only happens when i turn. Running it in 4wd for a bit and then going back to 2wd helped a bit for a little while but now it's back.
It's a 2005, with only about 45000 miles on it,driven mostly on dirt roads and highway, nothing extream. seems kinda young to have u-joint or wheel bearing issues... I dunno.....
thanks for any suggestions you can give.
