boston jeep...question
Remember that when you go SOA your steering components have to be completely relocated, get a good kit or experienced mechanic do to this for you since messing with steering components on a street driven rig can spell disaster if done improperly. Your steering wont necessarily be bad, just different than stock, im not sure how going SOA will affect bump steer, maybe one of the guys can give some input on that. As for the traction bar, it will reduce axle wrap, but is kinda spendy, just one more thing you have to buy. If your going to wheel your rig hard, and I assume you are if your going to the trouble to do an SOA, the traction bar might be a good investment. But like Snitty said a stiffer spring will definetly help, but the ride will be stiffer, so if you dont plan on doing extreme stuff just try the stiffer spring and see how that works. A steering stabilize will only help so much, and mine just slightly corrected wander. I am curious as to what the guys will say about bump steer, i hate bump steer.
