Jeepguy97
I have a 97 TJ which would mean I'm dealing with a dana 35. I was wheeling a few weeks back and the rubber fill plug somehow fell out... water and debris went in and now the pinion bearings are shot...
I love working on my Jeep and usually do all the maintenance, grew up on a farm and can fix about anything. I thought I'd have to wait till I could save up about 800 to get the job done because I dont have the experience or tools to set preload and backlash. (im a college student and 800 is hard to come by) anyway some guy i talked to yesterday said that as long as i reinstall the same pinion and ring gears with the EXACT same shim arrangement i should not have to set backlash. in fact he said that changing the shims would only move the used gear set out of its wear pattern and make things worse. As for pinion preload, he said i could figure that out with a in-lb torque wrench.
i can afford a bearing seal kit and could get to work on it right away. if i have to have a garage do it, my transportation will be laid up for a while till i can get the money
I'm just looking for a little encouragement and maybe a few tips or things to watch out for... Thanks in advance!!!
