I finally got a chance to get my shackles on. I built my own 1.25 lift. My Jeep actually drives a little better with them on. I know some will say the longer you go the worse your steering gets off, but I havent seen any problems so far. I did smoke 4 sawzall blades trying to cut the rear upper bolt off till a buddy came over. He suggested we take the fuel tank loose, and I said O man. We took the 7 bolts out and put a floor jack under the tank and just slid it around enough to pull the dolts right out. So dont try a sawzall it aint gonna cut the mustard. After that 30 minutes later we had it back on the ground.
