1. Using a trim stick C-4755 or equivalent, release the clips (2) and rotate the lower center trim (3) down and release the tabs (1).
2. Using a trim stick C-4755 or equivalent (2), release the clips in the rear of the upper trim (1).
3. Rotate the upper trim (2) back and release the front (1).
4. Disconnect the electrical connector (4) and remove the upper center cover (1).
5. Remove the screws (2) and using a trim stick C-4755 or equivalent, separate the center bezel (1).
6. Disconnect the HVAC control cables (1 and 9) and disconnect the electrical connectors (3).
7. Remove the screws (2) and remove the center I/P trim panels (1 and 3).
Please View the attached Pics. to relate to the Procedures. i hope this helps. Terry, if you want i can E-mail you this or any info. you need to post out for the members . just let me know.
