Nightmare Edition
Be got a 2007 wrangler x, the worst of the jeeps when it comes to DW. I've had a few things replaced , hoping to fix it. But those thing didn't cure it. Shocks, steering stabilizer, front end alignment, ball joints. What has cured it so far is new rims. The ones I had could not be weighted on the outside, only the inside and stick weights inside the wheel. I was lucky and was able to get some original rims from big o, that they jut took off a wrangler. So far driving on the worst roads I can find, no wobble. My advise is a new stabilizer and rims that can be properly balanced with weights on both sides of the tires. I'm driving relaxed and not caring about the roads , like I used to do. One dealership says the problem is mainly from the stabilizer and the wrong rims. So far it's cured mine. Maybe this info will help others !!!
