I got my 94Yj in June and i am a little new at this. I got the RE 2.5 and went to put on the front leaf springs. The directions say connect the front and rear of the leafs then the axel. I connected the front and the rear of the front leafs and the axel would not line up with the hole on the axel and the nub on the leaf so i un bolted the leafs and bolted the axel on the leafs so the nub on the leaf lined up on the axel. Then with the rear of the front leaf attached and the axel attached to the leaf the front of the leaf was off to the left at least a inch and a half. with almost 8 hrs of work into the front end i finally called RE the guy said you have to take off the track bar to make everything line up. Now i do not have a problem with removing the track bar but they make no mention of removing the track bar in the instructions. after 8 hrs of work and trying to figure this out the lack of this vital information in the instructions is what pisses me off.
I am looking forward to going home tonight and taking off the track bar and getting the front done. I guess the point of my venting is - does anyone know of any undisclosed problems i might run into with the rear and i guess in all fairness to RE is removing the track bar something i should have known on my own ??
