Those wires are most likely dimmers/illumination for the radio. I would NOT trust one persons wire colors versus another, manufacturers do not use a singular set of wire colors for a radio sometimes. especially from year to year. It would be better if you use a multi meter and verify what is what.
First, make sure the fuses are good, find a solid chasis ground and then find the hot wire (12 volt) this will go to the yellow wire on the after market radio.
Turn the ignition to acc and find another wire with 12 volt. thsi goes to the red wire inthe new harness.
Turn on your parklights, test for 12 volts, this is a dimmer.
One constant is all Chryslers had either a braided steel ground or it is a black wire. test for this using continuity when you think you find it, also turn on the park lights, some cars use a neg. trigger illumination wire. Dimmers and illumination wires just cap and set aside for now.
to find speakers, I like to use a 9volt batter and touch the wire to the terminals, once you hear a small thud sound, you have found the wires for that speaker. I like to seperate all teh speaker wires, then I find phase. with the speaker wire attached to teh battery, if the cone protrudes, the wire attached to teh positive terminal is the positive speaker wire. if the cone goes in towards the magnet, the wire attached to thepositive terminal is the negative wire.
