almost done with my motorcraft 2100 swap. it came from a 1975 jeep wagoneer with a 360, remanufactured, and its the 1.08 if all that helps.
1. first question...and most important. the choke on this carb is not electric, it appears to be the type that works off of heated air from the manifold. where can i run a hose from on my engine to get this choke working? i cant find anything to tap into or anything. or is there an alternative besides a manual choke?
2.even if i take the idle speed screw the whole way out it wont idle any lower than 1000 rpm's, what am i missing here?
3.i got the basic 9" air cleaner and the bolt that holds down the air cleaner will not work. it seems that the whole in the center of the carb is not threaded.
thats it for now.....im sure ill think of more :roll:
thanks in advance....
