pizaba
so,
i bought a pair of mirror relocators. they change the loc of the mirrors from the door to the side of the plates of the wind shield henges.
so here i am thinking this shouldn't be too complicated. i work at a tool repair shop, i have access to pretty much any tool, and if it isn't in the shop, i tell the owner and we have it next day. as soon as i start this little project, i see that the pair of mirror mounts don't come with bolts. ok no problem, i'll just use the original bolts. WRONG. i can't the *******s off. i've only tried on one bolt though. i stopped because i managed to strip the star out.
so, no problem, i'm down with buying new bolts if need be. its cool right?
thats where i am stuck at. i don't know what size/thread pitch these bolts are, mainly because i can't get them out. so my question is
a) what are the bolts i need to get to replace the original bolts on the wind shield hinge mounts?
b) how would one recommend getting the originals out? at first i used the correct fit of a star manually. stripped. attached said star to impact wrench. more stripped. said f u to star. went to easy-out set. stripped. am now considering using a radiac to cut flats into the bolts and win. but i don't really wanna slice into the hinges too much.
