GaryMB
OK, so i'm looking into cheaply lifting my jeep. I know questions like this have been asked before, but i guess i just need some clarification and opinion. I would prefer a spring over for clearance and flex purposes, but don't want to be too high up and don't want to get new drive shafts. Right now i have 1.5" HD shackles and am looking for better suspension flex and to fit at least 33's w/o rubbing. I came accross some bds yj 3.5" springs with 10k miles on them and a yj drop pitman arm for about $150. I already have extended brake lines and a t-case drop. I've looked into getting the front shackle conversion from rubicon express and it's 1" longer than stock shackles...so that's about 4.5" total lift, guess i could keep the rear shackles i have now to save some $. I would need new shocks. The thing is though, if these shackles were used on re's 4.5" lift springs like in their kit, wouldn't that yield about as much lift as a spring over? And if the re kits only use a t-case drop and shims to fix drive-line angle probs, would that be enough for a spring over?
