S Shawzzee New member Oct 19, 2019 #1 Hi all, I have already changed the power window switches. Passenger side will still not go up. Any ideas? Thank you. Sent from my iPhone using Jeepz.com mobile app
M mark sr Member Oct 20, 2019 #2 If you have power going to the window motor the odds are the motor is bad.
JPNinPA Well-known member Oct 20, 2019 #3 Wires going through door hinge break. Is there a plug inside the foot well Sent from my iPhone using Jeepz.com mobile app
aggreX Member Oct 20, 2019 #4 Remove inner door panel to access wires and motor. Check for 12V power to motor.
S Shawzzee New member Oct 21, 2019 #5 Got it, motor was bad. Tested wiring all the way. It was all good. Borrowed motor from drivers side and ran it backwards to get the window up. Sent from my iPhone using Jeepz.com mobile app
