Oil leak at filter bracket
bwdean
Help, My 4.0 6cyl has developed a leak at the oil filter bracket. I do not see a gasket so I assume that there are o-rings at the engine / bracket. My question is how does the bracket attach? All I see is a single 5/8" (wrench size) hex bolt head. Is this the mounting bolt?
1043095
what year is your jeep? my friend has a '94 grand cherokee and the filter bracket has been recalled and replced with a bracket that aligns the filter in a different way. i think it makes it parallel to the ground rather than at the angle a stock setup. [addsig]
1043098
1993 G. Cherokee, filter installs in the bottom up position. I have not seen any recalls on the filter bracket. Just a boat load of others though.
1043112
ok... i talked to my buddy... and instead of paraphrasing my conversation with him i'll just let you read it and take it for what its worth. (i'm dingus84, he's matt)
Matt83840: its not a recall
dingus84: ...
Matt83840: offically
dingus84: did yours leak?
Matt83840: but the dealers / mechanics recomend it
Matt83840: a little
dingus84: yeah
Matt83840: not much to woory about though
dingus84: yeah but his is leaking a good bit i assume
dingus84: where did you get yours done?
Matt83840: over the summer
dingus84: WHERE
dingus84: not when
Matt83840: some redneck mechanic in collegeville
dingus84: ah
dingus84: ok
dingus84: what would you call it
dingus84: ?
dingus84: oil filter alignment doohickey?
Matt83840: oil filter adapter
Matt83840: it just turns the postistion of the filter and moves it away from the engine block
Matt83840: the block heats up and makes the o-ring break on the filter
