No power to fuel pump
Troywil
04 wrangler. Died at a stop sign and would not start again. Engine cranks. Changed fuel pump. Checked all fuses. Changed the crank sensor. The pump makes no noise. The only thing that seems different is that when I put the key in to start it, there is a dash light with a key and a bat through it that comes on on the dash leading me to believe something has gone wrong with the security feature in the ignition. Any chance this is an easy fix?? Anyone have this problem before?
just a shot in the dark , disconnect your battery for at least half an hour . then try to start it.
Oh god ,not the key .:funny: But very possible these days.
Check your battery (load test) Then check and clean all battery connections.
Check all fuses and fuel pump relay
If you changed the CKP crank sensor, did you use OEM?
Was there a paper gasket on the end that went into the bell Housing?
Non OEM are bad out of the box at times and if there was no gasket the flywheel breaks the new one on the first crank.
