muduptomylips
Okay, I was driving and the jeep ran out of fuel although I had a quarter tank. Will not restart. It was running perfect before this issue. Pulled fuel lines off the fuel filter and they are dry. Put starter fluid in and will run till it burns off then nothing. A long time ago the vapor canister was dripping fuel after filling the tank. Once tank burned off a bit it never leaked at the canister again, however, I never fill past half because of that issue...never fixed just avoided. No I hooked an oil pump to the fuel lines and no fuel comes out no matter how long I pump, but I can hear a hissing sound on the vapor canister that is coming from the line that goes back to the fuel tank. If I pinch off that line the hissing stops, but still no fuel. What might be the problem as the mud is on its way. Need to get this thing rolling.
