No AC
jtlittle47
Replaced clutch and now it blows the clutch fuse everytime you hook up. I put an ohm meter on it and it reads a direct short rx1. I checked the old one and it has the same reading and blows the fuse. What do I check since this is the only thing I am trying to get to work. I can not get the clutch to energize so I can check the compressor. I have traced the wiring and it seems right. From the fuse to the connection. It does not blow until you hook up the clutch. Can I have gotton a bad clutch new?
Help. 2002 Jeep Liberty Limited 4x4
John:???:
I'd say that part is bad out of the box if the fuse doesn't blow until you plug the connector in.
