1077058
In my search for the 11/16 Alan wrench to change my Gear oil I have learned a little trick. This tool can only be bought from like the Drive around "Snap-on" dealers. Here is how you avoid having to search for that guy and change your gear oil yourself.
What you need:
1 x 11/16 hex head Bolt (The head of the bolt must fit an 11/16 wrench)
2 x Nuts for the above
Build your own Drain plug wrench:
Tighten the nuts all the way down on the Bolt,
BANG!!!!!! place the head of the 11/16 hex bolt into the drain plug and use the Nuts to place a wrench on to take it out.
Trick passed on to you all.
P.S. This works on VW's also ;-)
edited by: L33TJ33P, Jul 19, 2003 - 12:11 AM[addsig]
What you need:
