For the most accurate reading, hook it up to the vector displacement unit on the output side of your driveshaft. Also make sure it's grounded to the velocity indicator component,that's very important.
don't forget the gizmat sensor on the chrome reverse muffler bearing, unless your not using the G-Force option..
have to be really careful with that, it will set off the auto eject if not wired in sequence..
Sorry to say, it looks like you have become happily twisted like the rest of us, and there is no cure for it. Not even a 12 step program to help you with your condition, it's a direct result from driveing on those trails that the devil himself created to screw with us. Little did he know, we like it that way. just prey that your family dosnt get bent to far out of shape about it. If your ever in virginia let me know and we'll hit Devils path, and maybe do a little gerbil hunting.Ok instead i will just hook it up to the e-vac brass custom explode valve the put the hot to the underscore fire retro exhaust clip under the transmission.
Buck hour said:The vacuum advance on my flux capacitor is 4% to rich. Has anyone else had trouble with time travel?
