I have a 258 that had the stock single barrel carb. I am replacing it with an alluminum intake and holley 390 cfm carb. On the one barrel there was a copper line running from the side of the carb to the top of the exaust manifold. What exactly is it and where on the holley would I hook it up? Any other tips or tricks to hook the new carb up would be appreciated. The single had a vacume line running from the side it to a fitting on the side of the old intake. Do I need to use this? The used alluminum intake has this fitting pluged off(located under carb).Thanks
