You'll be fine, just be careful. Just put a block of wood under the sump of the oil pan to raise the motor up. Make sure to undo the motor mounts first though. Be very very careful jacking up the engine from this point, and make sure to spread the load out. You really only need to support it if I remember correctly. Not much lifting...
