Snitty
i started the SOA 2 weeks ago.. and it has since been raining nonstop... i'm doing it in my back yard so i have to work with the weather/sun... i did the SYE so far, and that's about it... i've been driving to and from work (2 blocks away) in wrong wheel drive...
i bought a driveshaft 2 days ago... fixed yoke on the ends.. slip joint in the middle... same size joints as our stockers... would have been a lot easier to find, but i needed the slipjoint... i got it for 10 bucks at some scumbag junkyard... i took it to the hardware store to get it cut... i was gonna cut around the welds and redo that.. but i figured that precision was A)too much work and B)not necessary for a temporary deal... i had the hardware store cut it on their bandsaw so i got some good clean 90 degree cuts at the exact spots i wanted them.. had to cut out 10"...
so.. how to make sure it is put together right so it keeps its balance from the already installed weights? well.. i look inside it and find the weld seam from when the pipe was made... and i mark that on the outside for them to be mated up to weld... then i found a piece of exhaust pipe that fit perfectly inside there snug... i cut the exhaust pipe to fit the length of the shaft.. leaving about 1/8" between the two halfs for weld to fill, i stuck it all together... i was goign to run a continuous bead all the way around it.. but figured not to for warping purposes... i decided to weld in spots to keep the heat down... this pic shows it almost completed... one half welded around...
if the pic doesn't work.. i'll move it to another server
i tried welding on low heat, continuously at first.. you can see that in the upper part of the pic... i went back over that and spotted it over...
50 mph... no vibrations
