Lift kits?
MattMayTJ
Hi I own a 97 TJ and I don't know a whole lot about any after market lifts so I thought I would ask you guys what you like to use
It's the 2.5L and it already has 31s on it and I don't want to go any bigger on tiers because I know you have to change out the gears
So what brand should I go with and what should I stay away from I know I do not want to do a body lift
I'd say the two biggest factors are how much can you spend, and how much lift do you want.
I think that most people with 31s opt for a budget boost, which is a spacer that sits on top of your existing springs. You can do a quality spacer lift including shocks for around $300.
Xt master I like the rough country lift you posted I might go with that thanks
