I have an 05 jeep wrangler tj and i installed all led lights and the tail running lights don't work but the turn signals and break lights do.
What I Did:
Step 1 - I started from the front with the side markers and everything worked fine
Step 2 - I then did the front turn signals and everything worked but the turn signals hyperflashed
Step 3 - I put in the Reverse lights and those worked fine
Step 4 - I replaced the Flasher relay to fix the hyper flashing and it worked but would click a couple more time after turn signals were shut off
Step 5 - I put in the rear running/break lights and the turn signals and break functions worked but the running lights did not
What did I do wrong and/or how do I fix this?
What I Did:
