Jeep CJ7 Hardtop
JBMP5
Hello all, was wondering if a 1977 CJ7 Hardtop would work on a 200 Wrangler? Any advice would be appreciated! Thanks[addsig]
1069867
Didn't know they made Jeeps way back then
200 Wrangler
:-D J/K
Don't really know man. I do know that the tubs are the same, just not sure about the mounting.[addsig]
1069912
no,
CJ's used the hex bolts similar to the YJ to secure the hard top, TJ's ( assuming 200 is 2000) Use a clamp instead and the lip where the machine screws attach is not present.
Also the tail gates are different.
I also think the TJ is a bit wider, and the wheel base is a bit longer (about an Inch)[addsig]
1069916
One more question: would the windows out of a 1977 CJ7 Hardtop work on a 2000 Wrangler Hardtop? Thanks and my mistake on the first posting "200 Wrangler".[addsig]
1069948
No if you are looking for a direct replacement. The windows in the TJ top and a different shape and are a bit larger. Any glass comapny can get jeep glass, it is just flat glass and can be cut pretty cheap![addsig]
