Jeep 4.7
Starting the build in about a week. Waiting for the last couple of parts to come it.
what do you have so far? all i got is the crank and rods, hadent gotten a chance to order nething else or go pick out a good block to work with..
I ordered this kit to begin with
http://www.speedomotive.com/jeep_4.htm
but I got 30 over pistons and rings
I also have the injectors coming from Jakes
http://www.jakesracingengines.com/jeep page 2.htm
As for the cam and lifters I sell crane so I have to order those when I am ready. I figure that if I am going to do this I am going to make it nasty. I bought another cherokee to drive while my truck is out of commision. My block on my 2000 TJ is in good shape so I may as well use that one. Estimated HP in this configuration 269 hp and 339 ft/lbs of torque. We will see what happens.
Also anothr site with good info
http://www.jeep4.0performance.4mg.com/stroker.html
Talk to you soon
you want pistons deisigned for a 4.0 block... but tell them if you want a low or high compression ratio, it all makes a difference in what kind of pistons you get
I own eastcoastoffroad.com, One of the products that I sell is crane cams. I ordered the convensional piston piston instead of the high compression because I fear problems with detonation getting the compression to high.
IN a lot of the magazines when someone talks about their stroker engine they mention Hesco engine parts. I have looked at their website and they have a lot of 6 cyl stroker parts and assemblies.
I have used Clifford research 6 cyl intakes and exhaust.
Later,
Jackcal
iv heard of Hesco but there prices are a little outrageous, all i need are pistons, a cam i will be getting from crane or comp.
if you go comp, you will need a specialty grind, and that will be overpriced... go crane... they have a cam for our application... i emailed comp last year, and the cam alone was $230
dammm.. i thought comp had a cam for the jeep 4.0 but if they dont have a cam and i need a speciality grind cam ill stay with crane, thanks for letting me know snitty,
that was last year, they may have one now... or, they may have had one and just tried making a specialty sale... but crane does have a good choice cam
Right now wee do not have a catalog but if there is anything that you need please let me know. You can email me or you call me at 315-697-6211. We can get you just about anything that you are looking for and compete nationaly.
As for the cam, stick with crane they actually have a cam that is built for this application and I have not needed to shim the rockers on another cam before and I have never read anywhere about that being needed.
ok thanks darrin, i will let yoou know when i am ready to get a cam, thanks
