joejeepny
I have an 04 rubi that I just put a 1" body lift on. The wrangler mt/r tires were 30.7" tall (LT245/75R16/E). I just tried a LT285/75R16/D which is 32.8" tall. This tire is overall 2.1" taller with a radius increase of 1.05" which with all calculations considered should fit and it does. I believe I shouldnt have any problem with rubbing except when I turn full lock left or right they rub the frame. I would assume any tj with a larger tire may have to adjust the stops depending on wheel backspacing. So what I am getting to here is 32.8" is the size of most 33" tires. Why do they say you need a 4" lift to fir 33's and more to fit 35's when it took only and inch of body lift to get 33's on. Is the rubi lifted already. When you buy a 4" lift does it lift the rubi 4"'s. Whats up with this?
