mingez
Many of you are in "invisible mode" and perhaps don't know you are. If you see an asterisk next to your name in the "ONLINE USERS" window on the home page, you're in invisible mode. When the switchover to the new software occurred, I was somehow switched over to invisible.
-To change this, go to site map (upper right hand.. last tab)
-select "Edit Options" (under user control panel)
-and the first thing you'll see is a window entiled "Login and Privacy"
-The first selection is "Use invisible mode" ...deselect the box.
Now we can see you...assuming that's what you want.
