intalling a transfer case for 89 yj
mandarrin
i just need to replace my old tranfer case for the same one. what is involve for the process.i have an np231 with a manual ax5 an 2.5l engine.any help would be appreciated.thanks guys[addsig]
1066129
It's pretty easy once you get down there messing with it.
  • Drain the transfer case
  • Remove the rear driveshaft
  • Disconnect the speedo and vacuum harness
  • Unbolt the transfer case shifter linkage
  • Remove the 6 nuts holding the transfer case to the transmission
  • Reverse to install
If you run into a jam during the process, we'll help out any way we can. Shouldn't be too tough.[addsig]
