Immobilizer/Wiring problems?
deathb4decaf
My 2000 jeep gran cherokee is stoping while driving and a key light comes in. For instance, the power steering and gas stops. It will start back up just fine. After research, I thought it was the fob in the key but it was not. Then I disconnected and reconnected the battery terminals and it worked fine, then a few days later it started doing it again. This is definitly an inconvienence since i work 10 miles away.
Any insight helps!
Are you able to replace the batteries in your Key fob?
