O Oscar Gutierrez New member May 17, 2015 #1 Im not really sure if i have to replace that bar or just install a new relocation bracket has anybody ever done this before ?
Bounty__Hunter Super Moderator May 18, 2015 #2 You don't need to do anything with the front trackbar unless the front axle is noticeably off-center under the Jeep. You can often remove both trackbars from the YJ with no ill-effect in handling, if off-road performance is important to you.
