how to remove the high pressure power steering hose
philip29
hey i got a 95 jeep cheorkee and i need to remove the high pressure power steering and i not sure the best way to take it off.
but do you need to remove the right side fan because i tried to get a wrench in there .it's no room to move the wrench. comming from the power steering pump
If you have access to a Crows feet line wrench that uses a 3/8 ratchet, that would be the best tool to use. It could get into tight spots in different angles if you use a swivel head ratchet.
