8177
I,m sure some of you are following the FI install follies. As you know my wiring harness was severely butchered. I bet I don't have 10 inches of original wiring without some caveman splice or wire replacement. I need a wire that is hot in run and start. I have tried the red w/white tracer as some have and a bunch of wires going to the gages. No luck in that. I have looked at 9 or 10 diagrams on line and in my Chilton's and can either not locate the wire I need or if I do its only hot in run or start. Can someone tell me a spot on the fuse panel that is hot R/S. Honestly at this point I am worried about burning something up and I don't want to just try every wire. The connector on the steering colum has a few red wires. the stripped on is hot all the time any guess on the others. Also I am afraid to just keep cranking on the engine everytime I make a splice. thanks
Jim
			Jim
