Horn assembly question
Engir
Active member
I am looking to verify something I know this goes together but I am having an issue. The first image is of the horn ring I guess setted in the Wheel
The second image is showing where the ring sets, the lip.
So this is my issue I cannot figure out when attach the piece in the image below it will not tighten down the screws go tight but the piece is loose and rattles around?
I also cannot get the horn button to go on I can put on the piece above when it is off the wheel but not when it is on, I think this is because it is loose. also the horn button on the wheel below is there supposed to be a spring on the bottom?
moving.
there doesn't seem to be a spring in this guy's ad
here is a video showing how it all goes together though. starting at 4:24
