you would have to check lift height laws in your state. Just remember, jeeps are short wheel base and the higher you go the less stable it will be on or off road. For a daily driver I personally wouldn't go beyond 6" or so, with 35" or 36" tires. Depending on what model jeep you have, once you add that large of a tire you have to make sure your axles can handle the added weight and leverage the new tires will put on them. I would recommend a 4" lift with 33" tires
