1066132
No. Most 6cyl. transfer cases have a 23 spline input shaft, and yours is 21 spline. Stick with a 4banger transfer case, preferably from a Jeep with the same type transmission so you know the input length is correct.
There is more work involved, but you can swap input shafts from your stock transfer case into a case with a 23-spline input. Requires disassembly of the transfer case.[addsig]
