90growler
My '90 YJ has been doing something very strange. The line that runs from the fuel tank near the exaust on the passenger side seeps when I turn the motor off. It is releiving pressure from that spot and then it stops. Prior to this happening you could hear bubbles being blown in the tank. It worsens when the tank is full. Since I bought it in Nov. fuel vapor can be detected at random times while driving or especially after being operated. The TBI system is not under pressure when the vehicle is not operating. Does anybody have a diagram of how the emmissions lines should run from the gas tank? I found one of the lines totally disconnected with a screw in the end of it. I have no idea where it goes. Could the evap. canister be clogged?
My emmisions diagram:
